[OSRS-PROJ] PROJ 4.4.3 Released
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 20 07:38:26 PDT 2001
Folks,
I have prepared a PROJ.4.4.3 source release. This release includes:
o New proj_api.h include file ... a public include file only defining
stuff required by external applications. Please try to migrate to using
this though projects.h will still work as it always did.
o Added support for Canadian NTv1 datum shift files.
o Fixed 7 parameter datum shifting support.
o Added "epsg" translation file, translating all EPSG projected and
geographic coordinate system definitions into a PROJ.4 equivelent.
o Added cs2cs documentation on man page. Fixed up developer man page somewhat.
o Added pj_init_plus(), pj_is_latlong(), and pj_latlong_from_proj()
API entry points, though I don't think they are documented in the man
page at this time.
o Slightly better building for Windows.
o Various other minor bug fixes.
Full ChangeLog attached. Source available at:
ftp://ftp.remotesensing.org/proj/proj-4.4.3.tar.gz
ftp://ftp.remotesensing.org/proj/proj-4.4.3.zip
I hope to prepare a binary distribution for Windows in coming days, but if
anyone else would like to do this let me know. I am always looking for help!
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Rel. 4.4.3 2001/04/20
2001-04-20 Frank Warmerdam <warmerdam at pobox.com>
* Don't install test files in /usr/local/share/proj.
* Made WGS84 the default in proj_def.dat
* nad/test27,test83: Use -b flag for diff to avoid differences on
Windows due to CR/LF issues.
* src/makefile.vc: default to building "all".
* src/pj_init.c: call pj_open_lib() with mode of "rt" to ensure
correct handling of def files on DOS based systems.
* Updated for 4.4.3 release (pj_release.c, Makefile.am, etc).
2001-04-05 Frank Warmerdam <warmerdam at pobox.com>
* Introduce proj_api.h as a public include file with projects.h
now intended to be private.
* pj_datums.c: added ntv1_can.dat to list for NAD27 datum.
* nad_init(): added support for loading NTv1 style datum shift files.
* cs2cs.c: use pj_latlong_from_proj()
* pj_init.c: added pj_init_plus().
* pj_utils.c: new with pj_is_latlong(), and pj_latlong_from_proj()
functions.
* pj_strerror.c: added error -43.
2001-04-04 Frank Warmerdam <warmerdam at pobox.com>
* rewrote 7 param datum shift to match EPSG:9606, now works with
example.
2001-03-20 Frank Warmerdam <warmerdam at pobox.com>
* Added -DPROJ_LIB=\"C:/PROJ/\" in src/makefile.vc to provide for
a default proj data file search directory.
* Added HOWTO-RELEASE document in CVS.
2001-03-15 Frank Warmerdam <warmerdam at pobox.com>
* src/pj_apply_gridshift.c: fixed bug in pj_load_nadgrids() which
would sometimes result in the load function failing because of a
buffer overrun in the grid list string.
2001-03-14 Frank Warmerdam <warmerdam at pobox.com>
* added nad/epsg database of translations between EPSG PCS/GCS
codes and PROJ.4 definitions.
2001-02-24 Frank Warmerdam <warmerdam at pobox.com>
* Include +ellps in proj example as per suggestion from Michael
DeChaine.
2001-02-07 Frank Warmerdam <warmerdam at pobox.com>
* Cleaned up various warnings when compiled with -Wall.
2001-02-03 Frank Warmerdam <warmerdam at pobox.com>
* Added cs2cs.1 man page, and minor updates to nad2nad.1 and proj.1.
* Added pj_transform docs to pj_init.3.
2001-01-25 Frank Warmerdam <warmerdam at pobox.com>
* Fixed pj_init() check for WGS84 match as per Bart Adriaanse bug rep.
2000-12-15 Frank Warmerdam <warmerdam at pobox.com>
* src/makefile.vc: only delete proj.lib if it exists.
2000-12-01 Frank Warmerdam <warmerdam at pobox.com>
* Added proj.def to extra_dist in src/Makefile.am.
2000-11-29 Frank Warmerdam <warmerdam at pobox.com>
* Changed strtod() to proj_strtod() in strtod.c, and make use
of it in dmstor() to avoid having stuff like "5d10" interpreted
as exponential notation on MSVC.
2000-11-18 Frank Warmerdam <warmerda at cs46980-c>
* Patch from Craig Bruce to adjlon.c to avoid wrong results,
and near-hangs when adjusting very large numbers.
http://bugzilla.remotesensing.org/show_bug.cgi?id=27
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
