[OSRS-PROJ] PROJ.4 "proj=latlong ellps=GRS80" functionality?
Tue Aug 7 06:40:10 PDT 2001
Ed McNierney wrote:
> I'm having a hard time understanding how this functionality is supposed
> to work.  I've built PROJ 4.4.3 with no troubles (Windows 2000,
> Microsoft VC++) and everything seems to be working.
> I don't understand the results I'm getting from "proj=latlong
> ellps=GRS80", however.  I'm ultimately trying to use this in MapServer,
> where I have several input data layers in NAD83 decimal degrees that I'm
> trying to project to UTM.
> Here's the simple example I don't understand:
> C:\>proj -v +proj=latlong +ellps=GRS80
> #Lat/long (Geodetic)
> # +proj=latlong +ellps=GRS80
> -71 43
> -1.24   0.75
> That is, my input coordinate (-71, 43) is transformed to (-1.24, 0.75).
> What does this mean?  I would expect the output results to be either
> identical to my input (if the input data is presumed to be in the output
> ellipsoid or if GRS80 or WGS84 is the default) or I would expect them to
> be very slightly different (if the input ellipsoid is something else).
Ed,
As suggested the coordinates are being returned in radians; however, this
isn't the desired behaviour.  It should just returned them, reformatted,
in DMS or decimal degrees without any change to the value.  I have submitted
a bug in bugzilla on this issues.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
