[OSRS-PROJ] lcc projection
Emmanuel Verlynde
EVerlynde at isagri.fr
Tue May 15 00:38:13 PDT 2001
i need to convert geodesic coordinates Lat/Long from misc GPS in european, north-african and east states.
they're use different geodesic system wgs84, ntf, rgf93, etrs89... and want planar coordinates in a lot of projection planar system like UTM, Gauss Krüger, Lambert belge 72, Gauss Boaga, lambert 2 étendu, Bessel, etc.
i try to use proj4 in .lib format compiled in a windows executable project, and now i have succed to call projection function but results are bad.
ex: GPS (WGS84, Lat/Lon) => Lambert2 étendu (NTF)
0.0/0.0 259283.17194/-3387561.891
instead of => 600.0/-3546.0974626
static char *parms[] = {"proj=lcc","ellps=clrk80","lat_0=46d8'0.0\"",
"lon_0=2d20'14.025\"","lat_1=41d33'37.00\"",
"lat_2=47d41'45.65\"","x_0=600000.0","y_0=2200000.0"};
putenv ("PROJ_LIB=C:\\Temp\\proj-4.4.3\\ess");
if (ref = pj_init(sizeof(parms)/sizeof(char*), parms))
data.u = 0 * DEG_TO_RAD; // latitude
data.v = 0 * DEG_TO_RAD; // longitude
data = pj_fwd(data, ref);
maybe it's due to mistake in ellipsoïde parameter? can i take to proj4 an ellipsoïd's excentricity (l2+: e=0.08248325676)?
someone can help me to give projection parameter example in utm, gauss, bessel, lambert 2 or 72 of geodesic parameter from GPS in WGS84 or another system...
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
