[OSRS-PROJ] Linking Proj.4 in VC++
Hawkswan at aol.com Hawkswan at aol.com
Thu Sep 6 09:33:57 PDT 2001
I compiled the proj.4 library under VC++ using the makefile.vc.  Everything
went OK on that.  But when I try to link with the proj.lib, I get the
following errors and warnings:  Any suggestions as to what's wrong here?
 Thanks.
Jere Swanson
Linking...
LIBCD.lib(crt0dat.obj) : error LNK2005: _exit already defined in
msvcrtd.lib(MSVCRTD.dll)
LIBCD.lib(crt0dat.obj) : error LNK2005: __exit already defined in
LIBCD.lib(dbgheap.obj) : error LNK2005: _malloc already defined in
LIBCD.lib(dbgheap.obj) : error LNK2005: _free already defined in
LIBCD.lib(crt0init.obj) : error LNK2005: ___xc_z already defined in
msvcrtd.lib(cinitexe.obj)
LIBCD.lib(crt0init.obj) : error LNK2005: ___xc_a already defined in
LIBCD.lib(crt0init.obj) : error LNK2005: ___xi_z already defined in
LIBCD.lib(crt0init.obj) : error LNK2005: ___xi_a already defined in
LIBCD.lib(winxfltr.obj) : error LNK2005: __XcptFilter already defined in
msvcrtd.lib(MSVCRTD.dll) : error LNK2005: __setmbcp already defined in
LIBCD.lib(mbctype.obj)
LINK : warning LNK4098: defaultlib "msvcrtd.lib" conflicts with use of other
libs; use /NODEFAULTLIB:library
LINK : warning LNK4098: defaultlib "LIBCD" conflicts with use of other libs;
Debug/Wayne.exe : fatal error LNK1169: one or more multiply defined symbols
found
Error executing link.exe.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20010906/7542c97f/attachment.html>
