[OSRS-PROJ] PROJ 4.4.4 Release
Sat Sep 15 22:17:07 PDT 2001
Folks,
I have prepared a new PROJ.4 release, version 4.4.4.  I am issing this release
primarily to get a new version of the epsg initialization file out there.  The
one released in 4.4.3 was badly broken for all LCC projections, and any
projections with non-meter units.  Noteably, this made the state plane support
done via the epsg initialization file next to useless.
This is also intended to be the release to correspond with MapServer 3.5, and
I suppose the GDAL/OGR 1.1.5.
The new code is available at:
   ftp://ftp.remotesensing.org/proj/proj-4.4.4.tar.gz
   ftp://ftp.remotesensing.org/proj/proj-4.4.4.zip
The full changelog reads:
2001-09-15  Frank Warmerdam  <warmerdam at pobox.com>
	* src/geocent.c: I have modified the Convert_Geodetic_To_Geocentric()
	function to clamp Latitudes just a little out of the range
	-PI/2 to PI/2 and to no longer do error checks on Longitudes since
	they will be auto-wrapped by sin() and cos().
	See http://bugzilla.remotesensing.org/show_bug.cgi?id=17
	* nad/epsg: commited new updates with fixed units for us state plane
	zones in feet, as reported by Marc-Andre.
2001-08-23  Frank Warmerdam  <warmerdam at pobox.com>
	* src/makefile.vc: improved the setting of PROJ_LIB defaults.
	* src/pj_open_lib.c: added the pj_set_finder() entry point.
	* nad/epsg: fixed all LCC projections.  The parameters were badly
	mixed up.
2001-08-11  Frank Warmerdam  <warmerdam at pobox.com>
	* src/proj.c: Generate an error message if +proj=latlong is used with
	this program.  As per bugzilla bug 70.
2001-06-01  Frank Warmerdam  <warmerdam at pobox.com>
	* makefile.vc: emess.c directly linked into mainline programs.
	* pj_errno.c: added pj_get_errno_ref().
2001-05-14  Frank Warmerdam  <warmerdam at pobox.com>
	* upraded config.sub and config.guess as per debian bug report 97374.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
