[OSRS-PROJ] PROJ4 and Krovak projection (Czech Republic)?
Markus Neteler
neteler at itc.it
Wed Apr 3 08:23:00 PST 2002
I am curious if it is possible to define the Krovak projection
in PROJ4 (finally I want to do that in GRASS).
The definition is:
http://www.ihsenergy.com/epsg/guid7.html#1.4.3
Parameters:
Ellipsoid Bessel 1841 a = 6377397.155m 1/f = 299.15281
then e = 0.081696831 e2 = 0.006674372
Latitude of projection centre (j_c) 49° 30'00" N = 0.604756586 rad
Longitude of Origin 42° 30'00" East of Ferro
Longitude of Ferro is 17° 40'00" West of Greenwich
Longitude of Origin (l_c) 24° 50'00" East of Greenwich=0.433423431 rad
Latitude of pseudo standard parallel (j_1) 78° 30'00" N
Azimuth of centre line (a_c) 30° 17' 17.303"
Scale factor on pseudo Standard Parallel (ko) 0.99990
Easting at projection centre (Ec) 0.00 m
Northing at projection centre (Nc) 0.00 m
Projection constants:
B = 1.000597498
A = 6380703.61
g 0 = 0.863239103
t0 = 1.003419164
n = 0.979924705
r0 = 1298039.005
It might be also called "S-JTSK Ferro Krovak".
As being only experienced a bit with Transverse Mercator, I am a bit
lost with this Krovak projection.
Thanks in advance for any hint (or a proj command line...)
Markus Neteler
PS: There is also another description with all history:
http://www.asprs.org/asprs/resources/grids/index.html
-> The Czech Republic
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
