[OSRS-PROJ] Build problems with GEOTiff and PROJ
Frank Warmerdam
warmerdam at pobox.com
Mon Aug 12 16:37:19 PDT 2002
Hopper wrote:
> I've compiled and installed PROJ.4, built from the latest stable source
> using GCC 2.96 on Mandrake 8.2. Install went good, and ldconfig -v shows a
> functional link to the library. I went with the default install location,
> and added the appropriate path into lib conf: libproj.so.0 ->
> libproj.so.0.3.1
> When attempting to build GEOTiff with the --with-proj, the configure script
> fails to find the proj libraries. Here's the error, verbatim:
> PROJ_HOME=yes, but either projects.h or libproj.a not found!
> checking for pj_init in -lproj... (cached) no
> checking for projects.h... (cached) no
> When giving a path to the proj library, I was still unsuccessful. Does
> GEOTiff need to be built against the PROJ source? I've been assuming that it
> was merely looking for the location of the directory.
Nathan,
The "(cached) no" can result from doing a configure with an old
config.cache around. I would suggest removing it and seeing if the
problem still remains.
If that still fails, delete config.status again and configure with
"--with-proj=/usr/local" and see if that works. If not, verify that
you have an installed /usr/local/include/projects.h, and
/usr/local/lib/libproj.a.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
