[OSRS-PROJ] Docs for projection option parameters
Mike Schmidt mike at sepia.com
Tue Aug 20 04:46:14 PDT 2002
Hello, Paul
You will find that the parameters you mentioned, and a host of others, are
used only with specific projections. The file PROJ.4.3.pdf , Table3,
defines a number of them in the context of a specific projection. Each
projection has it's own requirements. I have no idea how complete this list
is; I suspect it's not complete at all.
Mike
At 04:42 PM 20/08/2002 +0900, Paul Selormey wrote:
>Hello All,
>Where can I found the documentation of all the supported parameters?
>There are some in the pdf documentations (could not find any in the man).
>Parameters like "alpha", "lonc", "lat_1/2", etc are not documented. Any
>help?
>Best regards,
>Paul.
>PROJ.4 Discussion List
>See http://www.remotesensing.org/proj for subscription, unsubscription
>and other information.
________________________________________________________
Mike Schmidt                        Systèmes Scientifiques SEPIA
President                              SEPIA Scientific Systems
Tel: 450-358-2266                  100 Richelieu, suite 2000
Fax: 450-358-2267                 Saint-Jean-sur-Richelieu
e-mail: mike at sepia.com        Québec, Canada J3B 6X3
http://www.sepia.com             http://www.intello.com
This email message is for the sole use of the intended recipient(s)
and may contain confidential and privileged information.
Any unauthorized review, use, disclosure or distribution is prohibited.
If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
To reply to our email administrator directly, select the following
<mailto:postmaster at sepia.com>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20020820/4a5ab2e6/attachment.html>
