[OSRS-PROJ] installing datum-shift files on HP-UX
Duncan Agnew
agnew at bilby.ucsd.edu
Tue Aug 20 13:45:58 PDT 2002
Gentlemen:
I have installed PROJ 4.4.5 on an HP-Unix system. The install had one
problem: the ASCII datum-shift files in nad were not copied to src/nad
and so were not installed in the /usr/local/share/proj area--so I
moved these files after the regular install, and ran "make install" in src/nad
with no problems. However, there seems to be a hitch in the programs'
finding the datum-shift files: cs2cs only does so on the second and later
coordinate pairs (but then gives the right answer), and nad2nad fails:
%cs2cs +proj=latlong +datum=NAD27 +to +proj=latlong +datum=NAD27
-117d 30d
117dW 30dN 0.000
%cs2cs +proj=latlong +datum=NAD27 +to +proj=latlong +datum=NAD83
-117d 30d
* * 0.000
-117d 30d
117d0'2.901"W 30d0'0.407"N 0.000
% nad2nad -i 27 -o 83 -r conus
Rel. 4.3.3, 23 Sept. 1995
<nad2nad>:
datum file: conus, failed: No such file or directory
program abnormally terminated
to demonstrate that the files are there, here is an ls and the line in
my .cshrc file:
% ls -l /usr/local/share/proj/co*
-rw-rw-r-- agnew 264392 Aug 6 21:05 /usr/local/share/proj/conus
% fgrep PROJ ~/.cshrc
setenv PROJ_LIB /usr/local/share/proj
I'd appreciate any suggestions.
And, three miscellaneous comments:
1. In the (generic) INSTALL file the instruction to use ./configure
should I think be ../configure
2. What is the third output value from cs2cs?
3. The Oxford English Dictionary (which I can get online) does
not have gradian. As this is probably new, redundant with existing usage, and
misleading (radians are not involved) shouldn't it be deprecated?
Thanks for producing such a useful system--I have already used it
to solve a mystery with some Arc/Info files (which claimed to contain projected
coordinates that used WGS84 but actually used Clarke 1866)--now, if I
can just get the datum shifts to work...
Duncan Agnew
Scripps Inst. of Oceanography
La Jolla CA USA
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
