[OSRS-PROJ] cs2cs and datum shift]
Roberto Vidmar
rvidmar at ogs.trieste.it
Mon Aug 26 01:42:12 PDT 2002
-------- Original Message --------
Subject: Re: [OSRS-PROJ] cs2cs and datum shift
Date: Mon, 26 Aug 2002 10:41:14 +0200
To: Clifford J Mugnier <cjmce at lsu.edu>
References: <OF625FF421.F9D24C30-ON86256C1E.005C2142 at lsu.edu>
Hi Clifford,
Clifford J Mugnier wrote:
>Roberto,
>For the inverse, you have to change the sign of the components for the
>translations AND for the rotations. The scale factor is one minus the
>reciprocal. Once you do that, then you should get sub-millimeter precision
>in duplicating what you started with.
I agree.
>Also, note that there are two different conventions for the sense of the
>rotations. The correct way is that used by NIMA as defining the WGS84
>Datum (Counter-clockwise rotations as in vector mechanics and physics).
>The ITRF people in Paris confused the math and they use clockwise
>rotations. What Firenze uses depends on whether they use American GPS
>software or French/Swiss software ...
I know.
>So when you diddle with the parameters you were sold; you SHOULD have been
>provided at least ONE test point to validate the math model you choose to
>use (PROJ4), versus what the results should be.
This is what I'm trying to validate, but I have no luck yet...
> The parameters are
>intended to be used from Latitude, Longitude, ellipsoid heights to
>Latitude, Longitude, ellipsoid heights.
The parameters I have should bring me from local datum (Roma40) that is
referred to heights above sea level to WGS84 that does know nothing
about geoid (AFAIK).
> The relation with elevation is dependant on geoid models (at both ends of the transform).
>Make sense? I hope so; if not, continue asking questions.
The geoid stuff is quite complicated and I know that many people are
deep inside this matter. From my point of view if I run a program with
some input and then again requiring the reverse transform I should
return to the same starting point. So either I called the program with
wrong parameters or it is buggy :-)
Now forget Abbazia Pisani (near Padua by the way..) and try this:
cs2cs +proj=latlong +datum=WGS84\
+to \
+proj=latlong +ellps=intl \
+towgs84=10,20,30,1,2,3,44 \
bb | \
cs2cs +proj=latlong +ellps=intl\
+towgs84=-10,-20,-30,-1,-2,-3,-44 \
+to \
+to \
bb | \
cs2cs -I +proj=latlong +datum=WGS84\
+to \
The bb file is:
11 45 77
My output is:
10d59'55.09"E 45d0'2.796"N 15.661
11dE 44d59'59.939"N 637.364
So:
1st:) The two outputs are different.
2nd:) Both are wrong.
Maybe I did not understand the syntax or my cs2cs is broken...
Any hints?
Roberto
Roberto Vidmar
___ __ __ OCEANOGRAFIA
/ / /__ /__ GEOFISICA
/__/ /__/ __/ SPERIMENTALE
Istituto Nazionale di Oceanografia e
di Geofisica Sperimentale
34010 Sgonico (TS) ITALY
Research Group: CARS
(CArtography and Remote Sensing)
Tel. +39 040 2140 336 direct
Tel. +39 040 2140 1 operator
E-mail: rvidmar at inogs.it
Roberto Vidmar
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
