[OSRS-PROJ] cs2cs and datum shift]
Roberto Vidmar
rvidmar at ogs.trieste.it
Mon Aug 26 07:28:58 PDT 2002
Frank,
Frank Warmerdam wrote:
...snip
> Overall, I don't know why you can't get the correct output value, but I
> imagine it is because a different mechanism is being used by IGM to
> express
> the 7 parameters than PROJ.4 is expecting. PROJ.4's 7 parameter datum
> shift
> code is based on NIMA Geotrans, and apparently matches the 7 parameter
> parameters
> as expected for method 9606 in the EPSG database. However, there are
> many other
> ways of expressing the transformation.
This is not a problem. Basically having translation, rotation and scale
means trying only 8 different parameter sets. The problem is that I
cannot convert back again to the starting point, even using a 3
parameter transformation.
At present I'm playing with the source code (so I must go deep inside
the problem, deeper than I supposed and wanted to do...). I'm trying to
understand if the problem is in the to/from WGS84 functions or in the
geodetic/geocentric one.
Trying a wgs84 to ellps=intl with +towgs84=0,0,0 and back again restores
latitude and longitude with a small error in height (1 cm) so I suppose
the trick is hidden in the WGS84 functions...
...snip
> Good luck,
Thanks for your help.
Roberto
Roberto Vidmar
___ __ __ OCEANOGRAFIA
/ / /__ /__ GEOFISICA
/__/ /__/ __/ SPERIMENTALE
Istituto Nazionale di Oceanografia e
di Geofisica Sperimentale
34010 Sgonico (TS) ITALY
Research Group: CARS
(CArtography and Remote Sensing)
Tel. +39 040 2140 336 direct
Tel. +39 040 2140 1 operator
E-mail: rvidmar at inogs.it
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
