[OSRS-PROJ] Donald Elliptic Projection for AT&T V&H Coordinates?
Gerald Evenden gerald.evenden at verizon.net
Mon Dec 2 06:51:43 PST 2002
I couldn't agree more with your message and it was inexcusably sloppy of the
USAMS to not verify their projection with the existing charts/numbers of the
French.
One of the biggest problems I've had in coding projections is to find numbers
to compare the execution of my code.  Once you leave the area of the 20 odd
projections supplied by the USGS GCTP, making comparisons is very, very
difficult..
Secondly, how close should the comparison be?  For conformal projections
and any involved in plane coordinate system usage, projections should agree
to 1 mm.  Some of my codings are more accurate than alternate
source code simply because I have found it trivial to extend the precision
of some series to the ~15 digit limits of type double.
Clifford J Mugnier wrote:
> Mr. Evenden,
> I was not upset, just pointing out historical facts on projection math.
> The French could not "correct their maps.  :-)" because the maps were
> already printed and the "Bosch" were occupying their country.  The work
> that the C&GS tried to interceed with was with the estranged French
> Topographic Corps residing in London.
> The French only "corrected" their math in 1948 after WWII.  It took the
> U.S. Army Map Service to (mathematically and figuratively) "bop" them in
> between the eyes with a ball peen hammer before they changed to a fully
> conformal Lambert conic.  By that time, the rest of Europe was on the
> European Datum, UTM Grid.  Some prior French colonies (in North Africa)
> still cling to that old artifact of the French Army Truncated Cubic Lambert
> Conic.
> Screwy or not, it's what's implemented is what counts for the locals.
> Cliff Mugnier
> LOUISIANA STATE UNIVERSITY
    ...etc.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
