[OSRS-PROJ] Build problems in CygWin
Norman Vine
nhv at cape.com
Fri Dec 6 13:50:36 PST 2002
Matt writes:
> Hi Norman,
> Sorry about being lengthy on the first post. I tried your suggestion,
> but still have the same result. I did some research and found a posting
> on a build problem on an unrelated library where they had the same
> error. The solution was to delete the ltconfig script. I tried that,
> but no luck. It didn't really make sense as the ltconfig script seems
> to customize to the O/S.
> Any other ideas?
Did you rebuild the configure script by running autoconf ???
FWIW - I usually rebuild all of the maintainer files
with something like the following
#! /bin/bash
export PATH=/usr/autotool/stable/bin:${PATH}
aclocal
automake -a
autoconf
./configure
make clean
make
If this doesn't work I would check your Cygwin installation
as this just worked for me on a fresh CVS checkout
Norman
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
