[OSRS-PROJ] datum-shift
Harald Wehr hwehr at hs-harz.de
Tue Feb 26 03:24:46 PST 2002
I want to convert some data from latlong/wgs84 to tmerc/bessel with
datum shift from wgs84 to potsdam-datum here in germany.  How do i have
to use the function? Are helmert-7-parameter as well as
molodenski-3-parameter implemented? I tried the following:
cs2cs -v +proj=latlong +to +proj=tmerc +ellps=bessel +lat_0=0 +lon_0=12
+x_0=4500000 +towgs84=-586,-87,-409 <<EOF
10.69079E 51.86134N
EOF
As result i get the following:
# ---- From Coordinate System ----
#Lat/long (Geodetic)
# +proj=latlong +ellps=WGS84
# ---- To Coordinate System ----
#Transverse Mercator
Cyl, Sph&Ell
# +proj=tmerc +ellps=bessel +lat_0=0 +lon_0=12 +x_0=4500000
# +towgs84=-586,-87,-409
#--- following specified but NOT used
# +ellps=WGS84
4409820.23
5748070.07 698.769
The result is not good enough. I expect something like that:
4409920 5748280.
Whats wrong here? I got the "towgs"-parameters from a another
helmert-calculation i found in the internet which work in another
program i have here and show the results i expected.
Can you tell me where the mistake is?
Thanks in advance.
Harald
Hochschule Harz
Projekt Mobiharz
Tel. 03943/626654
Email: hwehr at hs-harz.de
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
