[OSRS-PROJ] PROJ 4.4.5 Release Issued
Frank Warmerdam
warmerdam at pobox.com
Fri Jan 11 08:09:48 PST 2002
Peter S Galbraith wrote:
>>Folks,
>>Pursuant to the terrible bug with datum shifting (excepting the NAD27/83
>>conversions) I have issued a new PROJ release with the fix.
> Hi Frank,
> As a sanity check that I've built the Debian package correctly, I always
> run a few simple commands and check that the ouput is identical to what
> prior versions of proj produced.
> For example:
> $ cat > /tmp/test.dat
> -65 49
> -65.1 49.1
> 99 99
> -66 49
> -66 49.1
> ^D
> $ proj +proj=lcc +lat_o=48.5 +lon_0="-62.5" -m 1:111120 -f '%.5f' /tmp/test.dat
> -1.66309 51.62829
> -1.72670 51.73125
> -2.32805 51.65025
> -2.32415 51.75131
> Prior to this version, I always obtained a different output of:
> -1.66314 51.62596
> -1.72676 51.72892
> -2.32812 51.64792
> -2.32423 51.74899
> Is this a reflection of the fixed bug? Or is something wrong?
Peter,
This is a function of the default ellipsoid now being WGS84 instead of clrk66.
If you do the same, but add +ellps=clrk66 you will get your old answers. I
thought this changed before 4.4.4.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
