[OSRS-PROJ] C++ Compilation
Paul Selormey
paul at toolscenter.org
Sun Jul 7 22:14:23 PDT 2002
Hello Frank,
I do not understand. It is by changing the file names
to *.cpp?
Best regards,
Paul.
----- Original Message -----
To: "PROJ.4 Discussion" <osrs-proj at remotesensing.org>
Sent: Monday, July 08, 2002 12:36 PM
Subject: [OSRS-PROJ] C++ Compilation
> Folks,
> I have made a pass making the PROJ.4 library , and associated utilities
> compile fairly clean as C++ code. I have only tested this with MS VC++ 6
but
> hopefully it should work with gcc, etc as well. The changes are committed
> to CVS.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
More information about the Proj
