[OSRS-PROJ] How to add new ellposid?
Paul Selormey
paul at toolscenter.org
Sun Jul 21 20:55:04 PDT 2002
Hello,
pj_ellps.c is the likely place to update the ellipsoid.
I have being planning to add all the OpenGIS-defined
ellipsoid too.
If you are using the C++ wrappers in OGR you will need to
update a similar structure there too (just copied from Proj4).
Best regards,
Paul.
----- Original Message -----
To: osrs-proj at remotesensing.org
Sent: Monday, July 22, 2002 12:17 PM
Subject: [OSRS-PROJ] How to add new ellposid?
I want to add some new ellposid definition.
should i add it in pj_ellps.c and recompile it?
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
