[OSRS-PROJ] geod_api
Alan Forster Alan.Forster at mouchel.com
Sat Jun 1 08:21:55 PDT 2002
Thank you for your e-mail.
I am on leave until 10th June and will reply when I get back!
Regards,
Alan.
>>> osrs-proj 06/01/02 16:13 >>>
Regards,
Alan.
>>> osrs-proj 06/01/02 15:59 >>>
Regards,
Alan.
>>> osrs-proj 06/01/02 15:50 >>>
Regards,
Alan.
>>> osrs-proj 06/01/02 15:39 >>>
Regards,
Alan.
>>> osrs-proj 06/01/02 15:30 >>>
Regards,
Alan.
>>> osrs-proj 06/01/02 15:16 >>>
Regards,
Alan.
>>> osrs-proj 06/01/02 15:07 >>>
Regards,
Alan.
>>> osrs-proj 06/01/02 14:59 >>>
Regards,
Alan.
>>> osrs-proj 06/01/02 14:47 >>>
Regards,
Alan.
>>> osrs-proj 06/01/02 14:33 >>>
Hi Folks,
I work on earthquake relocations at university of potsdam and try to
change the
coordinate  transformation routines of the USGS to ellipsoid and datum
variable
routines. Therfore i encapsulate then proj code into a "Transformer
Class" and
it works well. See ANHANG:
Now iI use also great circle computations to applicate perhaps the
azimut angle
to the normal correction vectors  of a earthquake event. The routines
are fixed to
WGS 72 ellipsoid and I want to use the parameter settings like the
routine GEOD
to create similar Container class.
My question, is there a geod_api.h available like the proj_api.h to
realize this
or must I investigate the programming code of the geod.c tool.
With friendly geetings A. Weidauer
I try to create  a class container  for proj tools like this :
ANHANG:
//--- uCoordinates.hpp ----------------------------------------------------
#include "uConst.hpp"
#include "uObject.hpp"
#include <proj_api.h>
class cCoordinateTransformer : private cObject {
private:
 projUV p;
 projPJ PlainLL;
 projPJ Src,Dst;
 void SetCoordSystem(const char* aProjection, projPJ& pj);
public:
 cCoordinateTransformer();
 ~cCoordinateTransformer();
 void SetPlainLLSystem(const char* aProjection);
 void SetPlainSrcSystem(const char* aProjection);
 void SetPlainDestSystem(const char* aProjection);
 void cvsLLToPlain (tDouble Longitude,
                    tDouble Latitude,
                    tDouble& XDistanceKM,
            tDouble& YDistanceKM);
 void cvsPlainToLL(tDouble XDistanceKM,
                    tDouble YDistanceKM,
                    tDouble& Longitude,
                    tDouble& Latitude);
 void cvsPlainToPlain(tDouble XSourceKM, tDouble YSourceKM,
                      tDouble XDestKM,   tDouble YDestKM);
typedef  cCoordinateTransformer*  rCoordinateTransformer;
// --- Class implementation
 cCoordinateTransformer::cCoordinateTransformer(): cObject() {
  PlainLL=NULL;
  Src=NULL;
  Dst=NULL;
 cCoordinateTransformer::~cCoordinateTransformer() {
  if (PlainLL!=NULL) {  pj_free(PlainLL); }
  if (Src!=NULL)  {  pj_free(Src); }
  if (Dst!=NULL) {  pj_free(Dst); }
void cCoordinateTransformer::SetCoordSystem(const char* aProjection,
projPJ& pj)
{ char buffer[512];
  if (pj!=NULL) { pj_free(pj);}
  pj = pj_init_plus(aProjection);
  if (pj==NULL) {
   sprintf(buffer,"Cannot set projection \"%s\" !",aProjection);
   FatalError(-1,buffer);
void cCoordinateTransformer::SetPlainLLSystem(const char* aProjection)
{ SetCoordSystem(aProjection,PlainLL); }
void cCoordinateTransformer::SetPlainSrcSystem(const char* aProjection)
{ SetCoordSystem(aProjection,Src); }
void cCoordinateTransformer::SetPlainDestSystem(const char* aProjection)
{ SetCoordSystem(aProjection,Dst); }
 void cCoordinateTransformer::cvsLLToPlain(tDouble Longitude,
                    tDouble Latitude,
                    tDouble& XKM,
            tDouble& YKM)
    if (PlainLL==NULL) {
      FatalError(-1," lon lat to plain transformer ! Coordinate system
not specified !");
    p.u = DEG_TO_RAD * Longitude;
    p.v = DEG_TO_RAD * Latitude;
    p = pj_fwd(p, PlainLL);
    XKM = p.u/1000;
    YKM = p.v/1000;
 void cCoordinateTransformer::cvsPlainToLL(tDouble XKM,
                    tDouble YKM,
                    tDouble& Longitude,
                    tDouble& Latitude)
not specified !");
    p.u = XKM*1000;
    p.v = YKM*1000;
    p = pj_inv(p, PlainLL);
    XKM = p.u * RAD_TO_DEG;
    YKM = p.v * RAD_TO_DEG;
 void cCoordinateTransformer::cvsPlainToPlain(tDouble XSourceKM, tDouble
YSourceKM,
YDestKM)
    if (Src==NULL) {
      FatalError(-1," lon lat to plain transformer ! Source coordinate
system not specified !");
    if (Dst==NULL) {
    p.u = XSourceKM*1000.0;
    p.v = YSourceKM*1000.0;
    p=pj_inv(p,Src);
    p=pj_fwd(p,Dst);
    XDestKM = p.u *1000.0;
    YDestKM = p.v *1000.0;
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
