[OSRS-PROJ] One more help, please...
Paul Selormey
paul at toolscenter.org
Mon Jun 10 08:55:01 PDT 2002
Hello Frank,
> I see I neglected to explain why this was a concern to me. There are
> platforms for which a long is smaller than a pointer, and so they can't
> always be cast back and forth freely.
I see. Me no think that far :(
> Hmm, actually now that I think of it, it was only function pointers on
> some of the new 64bit systems that were actually 128 bits long. Anyways,
> I would encourage keeping pointers as pointers to reduce future possible
> compatibility problems.
That is right. I was using 64-bit Alpha processor machine at school running
32-bit WinNT!
> Hmm. Actually, I think anonymous structures is the wrong way to describe
this.
> I really mean nested structure definitions within a union, something like
this:
> typedef struct {
> union {
> struct {
> double central_meridian;
> double scale_factor;
> } tmerc;
> struct {
> int grid_zone;
> } nzgrid;
> } u;
> } PJ;
This seems to be the most elegant solution. We might also pull the static
decription text into the structures to avoid the thread issue raised.
However, I did a quick search for projections using the extra parameters
and got over 30 different projections.
The union could be very large. Is it okay?
> So that a value would be reference as pj->u.nzgrid.grid_zone for instance.
> Ideally the union could remain unnamed, but I don't know if this is
portable.
No, this was not the form causing the problem. The Windows headers have
dummy name
for the unions.
Best regards,
Paul.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
