[OSRS-PROJ] <Update>:Initial step ready for testing
Mike Schmidt mike at sepia.com
Wed Jun 19 23:52:37 PDT 2002
Hello All,
In response to Paul's message, my initial thought would be that it would be
best to
crate a branch for this in the CVS for Proj4. This is the way we do this
kind of thing in
my company, and it makes the management easy. It definitely makes it easy
to check for differences
and such, and once the work is complete and tested, it can easily be merged
into the main branch
by the maintainer. This also allows the maintainer to make changes in the
main branch that do not get lost
in the final merge.
I don't have any experience at this time with the Proj4 or
remotesensing.org CVS conventions,
so I don't know if this is a reasonable approach in the circumstances.
Of course, Frank Warmerdam must be in agreement (and maybe create the
inital brnaching).
Mike
At 03:26 PM 20/06/2002 +0900, Paul Selormey wrote:
>Hello All,
>I wish to report that the initial part of my work on the Proj4
>library is ready. This initial part involves mainly removing the macros
>and some of the #defines.
>Unfortunately, the proj4 mailing list has no file section like the related
>lists being hosted on yahoo.groups so I do not know where to upload the
>files.
>I could send the files to anyone interested in testing the results, and I
>wish
>to post them to the related mailing lists file sections like the GDAL
>mailing
>list so that all can download it.
>Please I really need your support to complete this work. I have not yet
>started using the library in my projects and therefore cannot provide
>effective
>testing, please help. Simply use it as the previous and see if there is any
>change.
>There is no expected change, since the work so far is all about removing the
>macros to make the codes more readable.
>I am working on Windows and have created VC++6.0 workspace for the
>projection
>library. The workspace has
>1. proj4 DLL project
>2. proj4 static library project
>3. projects for all the utility programs like cs2cs, proj etc. The utility
>programs
>    are linked to the static library.
>4. A simple console test program, which uses the DLL version.
>I have attached a screenshot to show the workspace. I hope this will make it
>easier to Windows users with VC++6.0 to play with the sources.
>The "zipped" workspace is about 286 KB.
>The output of the projects are created in a subfolder/directory, named
>"Output".
>I have left the macros still in the sources - only commented them out.
>After enough test, I will remove all.
>Another request, please can you send me some test programs and data. It can
>simply
>be the proj.exe command line for various projections you use, some values
>and
>the expected output. These will help me test most of the projections. In
>fact, any
>other help will be very much appreciated.
>Please write directly to me if possible.
>Best regards,
>Paul.
________________________________________________________
Mike Schmidt                        Systèmes Scientifiques SEPIA
President                              SEPIA Scientific Systems
Tel: 450-358-2266                  100 Richelieu, suite 2000
Fax: 450-358-2267                 Saint-Jean-sur-Richelieu
e-mail: mike at sepia.com        Québec, Canada J3B 6X3
http://www.sepia.com             http://www.intello.com
This email message is for the sole use of the intended recipient(s)
and may contain confidential and privileged information.
Any unauthorized review, use, disclosure or distribution is prohibited.
If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
To reply to our email administrator directly, select the following
<mailto:postmaster at sepia.com>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20020620/08f1f67a/attachment.html>
