[OSRS-PROJ] <Update>:Initial step ready for testing
Paul Selormey paul at toolscenter.org
Thu Jun 20 00:26:24 PDT 2002
Hello Frans,
It is simple. You can start with www.wincvs.org for some Windows tools.
If you really want to get into it, a book on CVS is also recommend - there
is
a new book on it. I have it at home but do not remember the exact title now.
Best regards,
Paul.
  ----- Original Message -----
  To: 'osrs-proj at remotesensing.org'
  Sent: Thursday, June 20, 2002 4:06 PM
  Subject: RE: [OSRS-PROJ] <Update>:Initial step ready for testing
  Hello Mike
  You are taking about CVS. Do you have any information on how to set up the
CVS on a windows 2000 machine?
  Is it simple?
  Does it exists any package that sets up the CVS on a W2k-machine?
  Frans
    -----Original Message-----
    Sent: den 20 juni 2002 08:53
    To: osrs-proj at remotesensing.org; osrs-proj at remotesensing.org
    Subject: Re: [OSRS-PROJ] <Update>:Initial step ready for testing
    Hello All,
    In response to Paul's message, my initial thought would be that it would
be best to
    crate a branch for this in the CVS for Proj4. This is the way we do this
kind of thing in
    my company, and it makes the management easy. It definitely makes it
easy to check for differences
    and such, and once the work is complete and tested, it can easily be
merged into the main branch
    by the maintainer. This also allows the maintainer to make changes in
the main branch that do not get lost
    in the final merge.
    I don't have any experience at this time with the Proj4 or
remotesensing.org CVS conventions,
    so I don't know if this is a reasonable approach in the circumstances.
    Of course, Frank Warmerdam must be in agreement (and maybe create the
inital brnaching).
    Mike
    At 03:26 PM 20/06/2002 +0900, Paul Selormey wrote:
      Hello All,
      I wish to report that the initial part of my work on the Proj4
      library is ready. This initial part involves mainly removing the
macros
      and some of the #defines.
      Unfortunately, the proj4 mailing list has no file section like the
related
      lists being hosted on yahoo.groups so I do not know where to upload
the
      files.
      I could send the files to anyone interested in testing the results,
and I
      wish
      to post them to the related mailing lists file sections like the GDAL
      mailing
      list so that all can download it.
      Please I really need your support to complete this work. I have not
yet
      started using the library in my projects and therefore cannot provide
      effective
      testing, please help. Simply use it as the previous and see if there
is any
      change.
      There is no expected change, since the work so far is all about
removing the
      macros to make the codes more readable.
      I am working on Windows and have created VC++6.0 workspace for the
      projection
      library. The workspace has
      1. proj4 DLL project
      2. proj4 static library project
      3. projects for all the utility programs like cs2cs, proj etc. The
utility
      programs
         are linked to the static library.
      4. A simple console test program, which uses the DLL version.
      I have attached a screenshot to show the workspace. I hope this will
make it
      easier to Windows users with VC++6.0 to play with the sources.
      The "zipped" workspace is about 286 KB.
      The output of the projects are created in a subfolder/directory, named
      "Output".
      I have left the macros still in the sources - only commented them out.
      After enough test, I will remove all.
      Another request, please can you send me some test programs and data.
It can
      simply
      be the proj.exe command line for various projections you use, some
values
      and
      the expected output. These will help me test most of the projections.
In
      fact, any
      other help will be very much appreciated.
      Please write directly to me if possible.
      Best regards,
      Paul.
    ________________________________________________________
    Mike Schmidt                        Systèmes Scientifiques SEPIA
    President                              SEPIA Scientific Systems
    Tel: 450-358-2266                  100 Richelieu, suite 2000
    Fax: 450-358-2267                 Saint-Jean-sur-Richelieu
    e-mail: mike at sepia.com        Québec, Canada J3B 6X3
    http://www.sepia.com            http://www.intello.com
    This email message is for the sole use of the intended recipient(s)
    and may contain confidential and privileged information.
    Any unauthorized review, use, disclosure or distribution is prohibited.
    If you are not the intended recipient, please contact the sender by
    reply email and destroy all copies of the original message.
    To reply to our email administrator directly, select the following
    <mailto:postmaster at sepia.com>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20020620/6b6ec5e6/attachment.html>
