[OSRS-PROJ] <Update>:Initial step ready for testing
Paul Selormey paul at toolscenter.org
Thu Jun 20 07:52:13 PDT 2002
Hello Frank,
Thanks for the response.
> I will provide Mike and Paul with CVS update access, and accounts on
> remotesensing.org so they can put stuff on the ftp tree and so forth.
We will very much appreciate that.
> I am not enthusiastic about introducing a CVS branch for Paul's work since
> it seems to me it will continue to diverge over time from traditional
PROJ.4.
I do not hope to diverge from the traditional PROJ.4 with the current
version.
I will continue to improve the sources but maintained the tradition! Through
this,
I hope to have control over the sources and then start the C++ version,
which
may break the tradition, compatible C interfaces will be maintained for easy
update!
In any case, a different CVS tree is welcomed.
> However, Paul, if you would like I could clone the CVS tree for
> PROJ, and make you a proj_nt CVS project to start committing your changes
to.
Agreed. I will do my best to make the most out of it.
BTW, my response to your email bounced back, I will try to create a new
email account.
I have just found out that my ISP is listed in the blacklist and this might
be the cause of the bouncing back of my emails.
Best regards,
Paul.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
