[OSRS-PROJ] Exported function documentation
Paul Selormey paul at toolscenter.org
Tue Mar 5 04:11:46 PST 2002
Hello Frans,
> Have been able to compile the whole code without any warnings?
Yes, it went without warning at the VC++ warning level 3 (the default).
Actually, the #include <project.h> caused a lot of warning, but I fixed it
by telling the compiling to use the project directory as additional
"include"
directory and that was all.
The utilities, however, need some extra work.
> I am very intressted in your development of a com-inteface.
I need it too :-)
> Please let me know your progress.
The only thing is to understand the exported functions very well and
then wrap them. The OpenGIS stuff may however involve a little bit
of reading but I will give it a try,
Best regards,
Paul.
> Hello All,
> Where can I find a complete documentation of the following exported
function
> from the proj.dll?
> pj_init
> pj_fwd
> pj_inv
> pj_free
> pj_transform
> pj_geocentric_to_geodetic
> pj_geodetic_to_geocentric
> pj_deallocate_grids
> pj_init_plus
> pj_latlong_from_proj
> pj_is_latlong
> pj_get_errno_ref
> pj_set_finder
> pj_strerrno
> pj_errno
> If not, can anyone share his/her understanding on any of them? and if
> possible
> with sample codes? or even test programs?
> I have now started using the proj4. I have constructed Visual C++ for the
> main
> dll, applications (*.exe) and simple testing programs.
> I hope to provide a simple COM wrapper for the above exported functions,
to
> be
> used in VB and other projects.
> Also, trying to design a control which will serve as some form of
> user-interface to
> the EPSG file.
> Please let me know some of the things you wish to be done. I do not have
the
> technical
> knowledge yet to fix bugs in the algorithm :-) However, I will try to make
> it easier to use
> for the Windows programmer and I also make it ready for my own programs.
> Finally, I will be looking into how the proposed OpenGIS coordinate
> transformation COM
> interfaces can be exposed by the proj4, and how we could pull all into the
> .NET platform,
> stay tuned!
> Currently, working with the version 4.5.5. Any input will be highly
> appreciated. Unfortunately,
> this is mainly for the Windows programmer.
> To the Windows programmers, do you really use the utility programs like
the
> Nad2Nad.exe?
> Will you prefer a COM interface instead. Please let me know you needs :-)
> Please post any large file you wish to share directly to me in order not
to
> choke others
> mails. I will be posting the results to the sister mailing lists at
> Yahoogroups.com (such as
> the GDAL-DEV), which support file section.
> Best regards,
> Paul.
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
