[OSRS-PROJ] On Proj4...
Paul Selormey paul at toolscenter.org
Thu May 30 23:15:04 PDT 2002
Hello Glynn,
> To my mind, the "ultimate" solution would be to formulate the
> projection functions as high-level symbolic expressions, to allow:
> a) automatic conversion to any programming language, and
> b) higher-order operations, primarily differentiation.
Any concrete suggestions in this regard? Anything you have in mind will
help.
Best regards,
Paul.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
