[OSRS-PROJ] On Proj4...
Paul Selormey
paul at toolscenter.org
Fri May 31 03:16:24 PDT 2002
Hello Glynn,
Thanks for the guide. I will be considering this in my work.
Best regards,
Paul.
----- Original Message -----
From: "Glynn Clements" <glynn.clements at virgin.net>
To: <osrs-proj at remotesensing.org>
Sent: Friday, May 31, 2002 4:18 PM
Subject: Re: [OSRS-PROJ] On Proj4...
> Paul Selormey wrote:
> > > To my mind, the "ultimate" solution would be to formulate the
> > > projection functions as high-level symbolic expressions, to allow:
> > > a) automatic conversion to any programming language, and
> > > b) higher-order operations, primarily differentiation.
> > Any concrete suggestions in this regard? Anything you have in mind will
> > help.
> Well, the only real requirements would be that the format should be
> easier to parse than C-with-macros, and devoid of any assumptions of
> language-specific semantics. In particular, it would be nice to avoid
> the use of mutable state, so that functional languages could be
> supported easily.
> The bulk of the work would be in analysing all of the PJ_* files to
> determine the necessary feature set.
> Off the top of my head, I suppose that you would need mechanims to:
> a) declare projection parameters
> b) declare constants
> c) declare temporary variables
> d) define the actual equations
> e) indicate success/failure
> f) supply projection metadata
> Glynn Clements <glynn.clements at virgin.net>
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
More information about the Proj
