Fwd: Re: [OSRS-PROJ] On Proj4...
James Macgill
j.macgill at geography.leeds.ac.uk
Fri May 31 04:04:14 PDT 2002
Apologies if this arrives twice, but so far the first send appears to have
been eaten somewhere along the line.
>>To my mind, the "ultimate" solution would be to formulate the
>>projection functions as high-level symbolic expressions, to allow:
>>a) automatic conversion to any programming language, and
>>b) higher-order operations, primarily differentiation.
>>The existing format (i.e. macro-ised C) isn't particularly friendly in
>>that regard.
>I agree, that would be ideal. Is there an XML based equation or
>expression language that would be rich
>enough to capture the equations involved?
>I've been planning to write a script to convert the de-macro-ised C into
>Java for Proj4j. I've done a few by hand and so far it is generally
>little more than search and replace. That said, GeoTools, the project
>which hosts proj4j is in the process of combining with SeaGIS, another
>Coordinate Transformation project based around the OpenGIS standards, so
>its not clear how much further I will take proj4j.
>Is anyone on this list actively using the proj4j port?
>James
James Macgill
Center for Computational Geography
Spell Checker (c) Creative Spelling inc (aka my dyslexic brain)
http://www.geotools.org the open source java mapping toolkit.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
