[OSRS-PROJ] Re: Majordomo results: Hi
Fri Nov 15 08:22:38 PST 2002
srinivas reddy kanamatha wrote:
> Hi,
>   I am trying to convert the GPS data in to state plane coordinates. I
> am using cs2cs executable on windows to convert the data. Here is what i
> did
>    cs2cs +proj=latlong +datum=WGS84 +to +proj=lcc +lat_1=42.100000000
>    +lat_2=43.666666667 +lat_0=41.500000 to_meter=0.3048006096
>   When i enter the lat/long , i got erronous output. I am not sure if i
> am doing it correctly. But i would like the output in x,y,z when keyed
> in lat/long.
>   I would appreciate if some one can help me out. Please let me know if
> I am not clear.
It would be helpful to know what state plane zone you are working with,
what your input was, what your result was and what you think you should be
getting.
Normally, you would use a command like the following to convert from WGS84
to state plane zone 5010 (Alaska Zone 10 - NAD83 - meters):
cs2cs +proj=latlong +datum=WGS84 +to +init=nad83:5010
The full definitions of the state plane zones can be found in the nad27 and
nad83.  Usually found in /usr/local/share/proj.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
