[OSRS-PROJ] Re: Majordomo results: Hi
srinivas reddy kanamatha srinivas_k_reddy at hotmail.com
Fri Nov 15 10:36:07 PST 2002
  Yes. I copied the command line correctly. I am trying to convert the WGS84
to NAD27:2113 (michigan south ).
   I keyed in the following input
lat = 42.329867
lon = -83.057190
The desired output should be xy =2345029.400940,305024.741194
and the program gives *\t* output. Please let me know if i keyed in the
wrong values.
I appreciate your quick response.
Thanks,
Srinivas.
Reply-To: osrs-proj at remotesensing.org
To: <osrs-proj at remotesensing.org>
Subject: RE: [OSRS-PROJ] Re: Majordomo results: Hi
Date: Fri, 15 Nov 2002 11:33:04 -0500
Srinivas -
Is that command line copied correctly?  I just took a quick look, and you
seem to be trying to use the Michigan South Zone SPCS.  You should provide
the longitude of the grid origin and the false easting of the CS (the false
northing is 0) by adding these parameters to the output CS definition:
      +lon_0=-84.366666667 +x_0=4000000
Let us know if that's not the problem.  If you still have trouble, please
confirm which SPCS you're trying to use, and give us some example input and
output coordinates.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: srinivas reddy kanamatha [mailto:srinivas_k_reddy at hotmail.com]
Sent: Friday, November 15, 2002 11:00 AM
Subject: [OSRS-PROJ] Re: Majordomo results: Hi
    I am trying to convert the GPS data in to state plane coordinates. I am
using cs2cs executable on windows to convert the data. Here is what i did
     cs2cs +proj=latlong +datum=WGS84 +to +proj=lcc +lat_1=42.100000000
     +lat_2=43.666666667 +lat_0=41.500000 to_meter=0.3048006096
    When i enter the lat/long , i got erronous output. I am not sure if i am
doing it correctly. But i would like the output in x,y,z when keyed in
lat/long.
    I would appreciate if some one can help me out. Please let me know if I
am not clear.
Thanks,
Srinivas.
_________________________________________________________________
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
http://join.msn.com/?page=features/virus
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
The new MSN 8: smart spam protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
