[OSRS-PROJ] Re: Majordomo results: Hi
srinivas reddy kanamatha srinivas_k_reddy at hotmail.com
Fri Nov 15 11:04:17 PST 2002
Frank,
   Thanks for your help. Now i could make it work. But i have one more tool
, i am just trying to compare the results.
  I am developing a pocket pc application and so I need more accurate
results to track the poles while driving . so , i am just worried how much
error the system generates.
Thanks,
Srinivas.
Reply-To: osrs-proj at remotesensing.org
Subject: Re: [OSRS-PROJ] Re: Majordomo results: Hi
Date: Fri, 15 Nov 2002 13:50:49 -0500
srinivas reddy kanamatha wrote:
>Hi,
>  Yes. I copied the command line correctly. I am trying to convert the
>WGS84 to NAD27:2113 (michigan south ).
>   I keyed in the following input
>lat = 42.329867
>lon = -83.057190
>The desired output should be xy =2345029.400940,305024.741194
>and the program gives *\t* output. Please let me know if i keyed in the
>wrong values.
>I appreciate your quick response.
Srinivas,
I tried this (note that the input coordinate is typed in after hitting
enter on the command, and the result is echoed back after hitting enter):
warmerda at gdal[179]% cs2cs +proj=latlong +datum=WGS84 +to +init=nad27:2113
+units=us-ft
-83.057190 42.329867
2345076.92      305049.76 0.000
This doesn't match your expectation exactly, but it is close so we must
have the right general parameters.   The error (roughly 50 meters) could be
related to datum differences not properly accounted for by the NAD83 to
NAD27
datum shift in the conus files.  It's hard to be sure.  How accurate do you
believe your expected response should be?
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
_________________________________________________________________
The new MSN 8: advanced junk mail protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
