[OSRS-PROJ] Donald Elliptic Projection for AT&T V&H Coordinates?
Ed McNierney
ed at topozone.com
Wed Nov 27 17:33:02 PST 2002
Duncan -
I will then thank your more successful Googling skills than mine - I didn't find it <g>. I'll muck around and see if I can figure out a more standardized description of the projection.
- Ed
-----Original Message-----
From: Duncan Agnew [mailto:agnew at bilby.ucsd.edu]
Sent: Wed 11/27/2002 6:50 PM
To: osrs-proj at remotesensing.org
Cc: agnew at bilby.ucsd.edu
Subject: Re: [OSRS-PROJ] Donald Elliptic Projection for AT&T V&H Coordinates?
There is a description of this projection at
http://openmap.bbn.com/doc/api/com/bbn/openmap/util/VHTransform.html
(at the bottom of the page). The code used is open-source (it appears)
and can be downloaded; go to http://openmap.bbn.com/ for information.
The actual conversion code contained inside the Java is from other sources,
and it is clear that this is something that even AT&T had difficulty
sorting out later.
I leave it up to the more expert to add this to PROJ, and to reverse-
engineer the ellipsoid used.
Don't thank me, thank Google.
Duncan Agnew
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
