[OSRS-PROJ] Re: Krovak / PROJ4 (+axis option?)
Thu Apr 3 09:38:02 PST 2003
Radim Blazek wrote:
> Hi Frank,
> as you probably know, Krovak defines X=-y, Y=-x, i.e. X is vertical axis,
> oriented down and Y is horizontal oriented to the left. But all
> GIS/GPS/... systems must use usual coordinate system where
> coordinates are in 3. quadrant.
> For example:
> 14.39862613611E 50.465671925N  LL
> X=1001120.05 Y=738666.75       Krovak
> x=-738666.75 y=-1001120.05     In usual coor system and all GIS
> Because:
> 1) Evenden's implementation of Krovak (PJ_kocc.c) returns by default
>    values in 3. quadrant (-738666.75 -1001120.05) and Krovak X,Y
>    is returned only with +czech option
> 2) All GIS applications require coor in 3. quadrant and there
>    is no reasonable way to switch axis outside PROJ4 only for Krovak
>    (For GRASS for example, I used code PJ_krovak.c from PROJ4
>     but modified the code to get negative signs.)
> 3) Current behaviour in PROJ4 is wrong anyway in my opinion, because
>    returns 738666.76,1001120.13 (switched signs but not axis)
> I suggest to change PJ_krovak.c in PROJ.4 as you can see below.
> That means to get values that most of applications require.
> Radim
> 136,137c139,140
> <       xy.y = ro * cos(eps) / a;
> <       xy.x = ro * sin(eps) / a;
>>      xy.y = -ro * cos(eps) / a;
>>      xy.x = -ro * sin(eps) / a;
> 199,200c202,203
> <       xy.x=xy.y;
> <       xy.y=xy0;
>>      xy.x = -xy.y;
>>      xy.y = -xy0;
Radim,
Rather than have a +czech switch specifically for the Krovak projections, and
instead of altering the sign conventions from the "usual", I would like to
introduce a generic mechanism at the pj_transform() level for alternate axis
orientations.
Something along the line of a +axis switch, where "+axis=en" means that
x axis = 'e'ast, and y axis = 'n'orth.  Then a coordinate system string
could specify alternate axis orientations as +axis=sw indicating that
X is a "southing" (or negative northing) and Y is a westing (or negative
easting).  I think this would be the right organization for Krovak right?
My thinking is that this isn't a "projection" issue, but rather at a higher
level a "coordinate system" issue which is why I think it should be handled
by pj_transform() and not effect the low level projections routines.
I would add that Krovak is not the only coordinate system with unusual
axis conventions but this is an area I have been "sweeping under the carpet"
in most of my work in PROJ.4, and OGRSpatialReference, so far.
I would also note that I intend to adopt Gerald Krovak code at some point.
I have no schedule for implementing generic axis support or migrating to
use Geralds Krovak (or simplified libproj).  I will not have time to even
look into this for several weeks.  Thus, for your own purposes you should hack
your local GRASS built in a manner suitable to your needs in the meantime.
I have taken the liberty of cc:ing this reply to the PROJ list where I hope
any discussion of a +axis switch can take place.  GRASS folks might also be
interested as it would presumably be the way that alternate axis orientations
are selected in GRASS.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
