[OSRS-PROJ] Stereographic inverse error
Gerald I. Evenden
gerald.evenden at verizon.net
Fri Apr 11 08:19:49 PDT 2003
The inverse of the stereographic (PJ_stere) seems to be fixed.
How should I forward the corrected routine?
It is for libproj4, and is now v. 2.2 (I started all libproj4
at first level 2). But this particular routine should be
compatible with older PROJ.4 libraries.
Autographed correction is being sent to bug finder.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
