[OSRS-PROJ] Reprojecting a point with CS2CS
Matt Lynch
matt at terraengine.com
Mon Apr 21 07:53:28 PDT 2003
I am trying to do some coordinate transformations with the cs2s utility.
I think I have the syntax correct, but the accuracy is off (I am using
ESRI ArcView to check the values). Perhaps my problem is really not
understanding either PROJ.4 or the ArcView application.
My test point is
Lat/long
GRS80
Unprojected
112.8330W
51.3275N
My first transformation is below:
C:\proj4>type wim.coord
112.8330W 51.3275N
C:\proj4>cs2cs +proj=latlong +ellps=GRS80 +to +proj=utm +zone=11
+ellps=GRS80 <wim.coord
790277.46 5694492.75 0.000
C:\proj4>
I reprojected the same point using ESRI with the following settings:
Category: UTM-1983
Type: Zone 11
Projection: Transverse Mercator
Spheriod: GRS80
Central Meridian: -117
Ref Lat: 0
Scale factor: 0.9996
False E: 500000
False N: 0
And get - 790298,5694496.266518
You can see it is close but not quite on. Any suggestions would be most
appreciated.
Thanks,
Matt
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.473 / Virus Database: 271 - Release Date: 4/17/2003
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
