[OSRS-PROJ] nad2nad bombing
Frank Warmerdam
warmerdam at pobox.com
Tue Apr 22 06:51:58 PDT 2003
Jack Bowling wrote:
> I have a series of GPS-ed UTM points done in NAD83 datum but the topo charts I have on which to plot them are *old* NAD27 using Clarke ellipsoid.
> I tried the following on my linux box to convert. The input file is just a text file of UTM pairs:
> $ nad2nad -i 83,utm=10 -o 27,utm=10 -r ntv1_can.dat < /home/jb/docs/birds/NOS/bowron/txt/utm83.txt
> Rel. 4.4.7, 31 March 2003
> <nad2nad>:
> datum file: ntv1_can.dat, failed: failed to load NAD27-83 correction file
> program abnormally terminated
> The ntv1_can.dat file is in /usr/local/share/proj. I did this last year in June using the then current version of proj with perfect results. Perhaps somebody can show me the errors of my ways.
> Yes, I know I should be using cs2cs instead of nad2nad if I want the ellisoid transform but the difference is within a few metres so it really is not that important on the scale of chart I am dealing with.
Jack,
The nad2nad program only works with the US style datum shift files, not
the NTv1 or NTv2 files. You will need to use cs2cs for this process;
however, it should not be difficult. Something like the following
will likely work:
cs2cs +proj=utm +zone=10 +datum=NAD83 \
+to +proj=utm +zone=10 +ellps=clrk66 +nadgrids=ntv1_can.dat \
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
