[OSRS-PROJ] libproj4 updates
Gerald I. Evenden gerald.evenden at verizon.net
Wed Apr 23 19:08:49 PDT 2003
Thanks for the info.  I am about half way through the internal
functions with most of the tougher ones completed (except for the
model of a projection routine).
Oops, I already see an error: the Authalic Sphere section should
name pj_auth.c as the file not pj_qsfn.c (which has been removed
from the Makefile list but mistakenly included in the .gz file).
The next release will contain the pj_rtodms function which will
be the library version of the old rtodms with a couple of changes.
On Wed, 2003-04-23 at 20:27, Paul Selormey wrote:
> Thanks for the updates. I have just glanced through
> the internals doc and it seems good - very good information in there.
> Best regards,
> Paul.
> ----- Original Message -----
> From: "Gerald I. Evenden" <gerald.evenden at verizon.net>
> To: "[OSRS-PROJ]" <osrs-proj at remotesensing.org>
> Sent: Thursday, April 24, 2003 1:06 AM
> Subject: [OSRS-PROJ] libproj4 updates
> > The libproj4 library has been updated to about 135 projections with
> > Transverse Cylindrical Equal-Area being the most significant addition.
> > Also revisions to the Internals pdf file have also been made.  For
> > copies of all this material go to:
> > http://members.bellatlantic.net/~vze2hc4d/proj4/
> > I have also included both an RCS wrapped archive as well as a plain file
> > copy .gz files.
> > PROJ.4 Discussion List
> > See http://www.remotesensing.org/proj for subscription, unsubscription
> > and other information.
