[OSRS-PROJ] Winkel Tripel or Winkel 3 Projection
Gerald I. Evenden gerald.evenden at verizon.net
Sat Aug 23 06:44:21 PDT 2003
On Sat, 2003-08-23 at 09:14, Paul Selormey wrote:
> Hello All,
> Is there a proj4-based implementation of these projection type anywhere?
> Or is there any proj4 support for compound projections?
Winkel Tripel is in the proj system.
Can't find any reference to Winkel III in Snyder's works.
If you have a reference, I'd like to look at it.
> Finally, is Gerald I. Evenden's site down?
> http://members.bellatlantic.net/~vze2hc4d/proj4/
Not that I know of.  I clicked the above and it came up.
> I have tried several times to access it without success.
Someone else try and report, please.  Thanks.
> Best regards,
> Paul.
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
Gerald I. Evenden <gerald.evenden at verizon.net>
