[OSRS-PROJ] Horrors of --- Krovak projection
Gerald I. Evenden
gerald.evenden at verizon.net
Fri Feb 14 10:43:35 PST 2003
In the example below (and checked with the web site) the longitude
seems to be a bit odd. The Czech Republic only extends from about
12 to 19 east longitude. The 35 lon puts the point somewhere in
Russia. Are you using a non-Greenwich meridian?
Current progs do not work on this example although they check on
examples in the region of application.
On Fri, 2003-02-14 at 11:37, Clifford J Mugnier wrote:
> Extracted from my January 2000 column on the Grids and Datums of the Czech
> Republic and still available for downloading from:
> http://www.asprs.org/asprs/resources/grids/index.html
> increasing South, and the orthogonal Y-axis is increasing West. A test
> point provided lists: φ = 48° 07' 46.2973, λ= 35° 42' 35.2147", Y =
> 504,691.675 m, X = 1,289,068.724 m.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
