[OSRS-PROJ] Horrors of --- Krovak projection
    Ron Russell
    ron at lsl.co.uk
    Thu Feb 20 00:49:02 PST 2003
Gerald I. Evenden wrote:
> This is just a short note on the status of the Krovak projection.
> The forward projection appears to be working in its native
> math-based mode.  Tests for conformality with the -V option
> show it is OK.  Math-correct x-y are in the -x -y quadrant
> for Czech geographic coordinates.
> Currently the execution script looks like:
> <S-JTSK> +proj=kocc +ellps=bessel +czech
>      +lon_0=24d50 +lat_0=49d30
>      +lat_t=59d42'42.69689 +lat_1=78d30 +k_0=.9999
> To generate Czech grid system values the flag option +czech
> must be used to shift math-x to Y and math-y to X, changing
> the sign to positive in Czech area.  That is plus y west of
> Helsinki and plus x south of Helsinki.
> Another factor to resolve is the longitude used by the Czechs.
> Test values of FORTRAN and C code examples us Greenwich PM
> data but one example obviously must use another meridian---
> perhaps the Ferro one.  The above script is set for
> Greenwich.
> Lastly, the inverse has to be added but once we have a
> good forward, this should not take as much time.
> If anyone is interested in the math I would be glad to
> email a pdf file---about 26k in .gz or 50+k in uncompressed
> form.  As far as I know, this is now the defining math
> for the Krovak in English.  Please ask for a copy, review
> it and let me know of any deficiencies.
> For hassles in using the Krovak in Grass, I suggest they
> use the native math form with false eastings and northings
> to get positive first quadrant values and not mess with the
> code.
> Lastly, I tried to make the basic projection modifiable for
> general applications.  Some simplifications in the cod were
> made so that future mods may be required for true generality.
> If I had included the total math there would have been a few
> more + options to worry about.
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
Gerald,
Can I please have a copy of the pdf file. The zipped version
is fine.
Ron
Ron Russell
Senior Software Engineer, Laser-Scan Ltd
+44(0)1223 420414
http://www.laser-scan.com
More information about the Proj
