[OSRS-PROJ] Pseudo X/Y values, forward and reverse
Frank Warmerdam
warmerdam at pobox.com
Thu Jan 30 14:02:44 PST 2003
William Hersman wrote:
> Input -175.1234589 59.7654305 DD
> Return -4054878.4814 2990301.082 ASP 4 FEET
> Input -4054878.4814 2990301.082 ASP 4 FEET
> Return -175.1487387 59.7638269 DD
William,
It would clearly help alot if you could provide the details of the
coordinate system. I tried this:
warmerda at gdal2200[237]% proj -I -v +init=nad27:5004 +units=ft
#Transverse Mercator
# Cyl, Sph&Ell
# +init=nad27:5004 +units=ft +proj=tmerc +datum=NAD27 +lon_0=-150 +lat_0=54
# +k=.9999 +x_0=152400.3048006096 +y_0=0 +no_defs +ellps=clrk66
# +nadgrids=conus,ntv1_can.dat
-4054905.40 2990291.47 (input)
175d7'10.261"W 59d45'56.295"N (output)
warmerda at gdal2200[238]% proj -v +init=nad27:5004 +units=ft
# Cyl, Sph&Ell
175d7'10.261"W 59d45'56.295"N (input)
-4054186.84 2990083.90 (output)
I see there is an over 700 ft difference in the positions. Far more than
I would have expected. In this case the longitude is 25 degrees away from
the central meridian for the zone, but I wouldn't have thought the
reversibility of the equations would have been so poor at that distance.
Cliff, you mentioned that the TM coordinates would not be reversible at
great distances. Is this the nature of the TM equations or a weakness in
their implementation with PROJ.4?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
