[OSRS-PROJ] projection formulation
a a
list672000 at yahoo.com
Wed Jul 30 08:04:51 PDT 2003
Hello.
I would like gdalwarptest to be able to output files in a particular "map projection". This list was recommended as a forum where folks might be able to suggest a suitable proj4 projection formulation.
I've attached a jpeg to this email that might communicate what I am thinking. I will try to describe it in words here. I want to reproject any equirectangular raster data that is above 45 degrees north or below 45 degrees south into a different "map projection". That map projection is described by the two squares at the bottom of the jpeg. If it is not clear from the jpeg what I am thinking, please let me know and I will try to describe using more words.
Thank you for your time.
Mike
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20030730/375a6063/attachment.html>
Type: image/pjpeg
Desc: equirectangularToSomething.JPG
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20030730/375a6063/attachment.bin>
More information about the Proj
