[OSRS-PROJ] projection formulation
Gerald I. Evenden gerald.evenden at verizon.net
Wed Jul 30 13:17:58 PDT 2003
Dividing the map into the three regions proposed would not be a
PROJ function.  The only thing that "might" be coded into PROJ is
the odd polar projection.  Why not use the polar aspect of
azimuthal equidistant (a projection nearly as simple as the
equirectagular)?  Don't look for me to do the polar projection
unless you can find a significant group to support such a
projection.
But dividing the data into the three graphic regions is still
not a function of PROJ as there are no features withing the
system to do the windowing.
On Wed, 2003-07-30 at 14:54, a a wrote:
> Gerald,
> Thanks for responding.
> gdalwarptest is an application that is part of the GDAL
> (http://remotesensing.org/gdal/) project.  gdalwarptest can be used to
> reproject a raster file.  gdalwarptest seems to make use of the Proj4
> library for its reprojection work.
> From your last sentence, I take it that (currently) there is not a
> PROJ projection formulation for the "projection" that I described.  If
> I am correct, where would the new projection code be added; and is
> there a projection that is already coded that I could look at as an
> example?
> Thanks.
>     Mike
> "Gerald I. Evenden" <gerald.evenden at verizon.net> wrote:
>         What is "gdalwarptest?"
Gerald I. Evenden <gerald.evenden at verizon.net>
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
