[OSRS-PROJ] proj.4 in VB
Alexander Weidauer alex.weidauer at huckfinn.de
Fri Jun 27 03:54:50 PDT 2003
Hi Christopher,
May be it is sensefull to write a ocx control for the proj library?
Has anybode sutch a control in C++ because I writing in Delphi and
it seem to be wrong to use a DLL written in C set on top a API in Delphi
and write a OCX to get it for visual basic ?
Bye Alex
Christopher Pouliot schrieb:
> Hello,
> I have downloaded the proj.dll file (v4.4.6) and am trying
> unsuccessfully to use it in Visual Basic.  The simple initialization
> code below causes a fatal error in VB and crashes the program.  My
> experience working with external DLLs is limited so any assistance or
> sample VB code would be greatly appreciated.
> Private Declare Function pj_init Lib "c:\software\proj\bin\proj.dll"
> (ByVal argc As Integer, ByRef argv() As String) As String
> Private Sub Command1_Click()
>   Dim anArr(2) As String
>   Dim aResponse As String
>   anArr(0) = "proj=utm"
>   anArr(1) = "zone=11"
>   anArr(2) = "ellps=GRS80"
>   aResponse = pj_init(3, anArr)
> End Sub
> Thank you,
> Chris
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
