[OSRS-PROJ] The "almost" Lamber Conformal Conic Projection
Mon Mar 3 20:46:01 PST 2003
Gerald I. Evenden wrote:
> Very interesting.  The results at this end from the script are:
> [gie at localhost src]$ ./lcca
> forward projection of:
> 34d08'11.291 37d31'17.625
> 15707.96        623165.96
> EPSG guide 7, pdf p. 22 gives values of: 15707.96 623165.96
> inverse check of forward
> 34d08'11.29100"E        37d31'17.62500"N
> Ahhhhhh---I see it. PUT "no_defs" in the script. "Spec'd but
> not used".   <<------------------------
> I will correct the lcca.txt script.
> Your local datum overrode the +b facor.  Look carefully at the
> beginning of the -V output.
Gerald,
Of course you are right.  I get matching results to the cm with the
no_defs as well.
The lcca projection has been committed to CVS and is in the 4.4.6 release.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
