[OSRS-PROJ] PROJ 4.4.6 Release
Paul Selormey paul at toolscenter.org
Tue Mar 4 00:48:19 PST 2003
Hello Frank,
Thanks for the effort. I have being waiting for this update. I will now
continue my work on the Proj4 and the COM wrapper.
Again, thanks.
Best regards,
Paul.
----- Original Message -----
To: "PROJ.4 Discussion" <osrs-proj at remotesensing.org>
Sent: Tuesday, March 04, 2003 1:15 PM
Subject: [OSRS-PROJ] PROJ 4.4.6 Release
> Folks,
> I have decided to kick out a PROJ 4.4.6 release.  A tentative attempt at
this
> is now available for download from the PROJ.4 page at:
>    http://www.remotesensing.org/proj
> The NEWS file reports:
> 4.4.6 Release Notes
>   o Incorporated new lcca (Lambert Conformal Conic Alternate) projection
from
>     Gerald.
>   o Updated 'espg' translation file for EPSG 6.2.2 with better support for
>     prime meridians.
>   o Added Prime Meridians via +pm command switch to cs2cs (and
pj_transform).
>   o Fixed bug with 7 parameter transforms.
>   o Added 'esri' pseudo-epsg coordinate system file.
>   o Cleanup so that PROJ.4 compiles clean as C++ code.
>   o Added pj_get_def() to expand definitions of stuff like +init clauses.
>   o Added a Krovak implementation (proj=krov).  Note this may change again
>     in the next release.
> Although not noted, this release also attempts to work well on Cygwin, and
> includes more recent versions of the automake, and libtool files.   If no
> problems are encountered I will announce the release more widely on the
> freegis mailing list, and freshmeat.net.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
