[OSRS-PROJ] ESRI File
Daniel Morissette
morissette at dmsolutions.ca
Tue Mar 4 12:42:04 PST 2003
Paul Ramsey wrote:
> Attached.
> Derived by: downloading all projections from ESRI's ArcXML reference
> site, parsing out of HTML, and then applying the OGR coordinate system
> functions to turn the WKT into Proj4.
> Paul
Thanks for this Paul. Unfortunately I think I didn't formulate my
question properly earlier today. What I'm trying to do is come up with
is a epsg file that will contain all the regular epsg definitions and
all the esri-specific projections. This is so that our WMS clients can
talk to ESRI WMS servers which advertize custom EPSG codes like
EPSG:102009.
Looking more closely at the file you sent I notice that there are a
bunch of definitions outside of the 0-32767 range. Do you know if it
would be safe to assume that any definitions inside the 0-32767 range in
the esri file are a subset of the ones in the epsg file, so to produce
my merged file for my WMS client I could use the latest epsg file from
PROJ 4.4.6 and append to it all definitions from the esri file with ids
above 32767?
I guess I could walk through the file and find out myself, but if you
know the answer to that question already then that would save me some
time. :)
Thanks
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
