[OSRS-PROJ] New projection routines??
Gerald I. Evenden gerald.evenden at verizon.net
Fri Mar 7 19:53:04 PST 2003
The original figures in the pdf distributions came from two
sources: MAPGEN and PLOTGEN and my device independent plotting
routine.  I have dropped doing anything with both projects as
they are pretty much out of date and I don't know anyone using
them.  Since gnuplot has been around a while and I figure I might
as well use it in any new effort.
Mike Schmidt has started on redoing the documentation but
the last I checked he had been stalled with other duties.
At the moment, my concerns are documenting new material
and not duplicating anything he does although I am interested
in getting the illustrations up to date.
On Fri, 2003-03-07 at 21:21, Paul Selormey wrote:
> Hello Gerald,
> Thanks for the commitment to the development of the Proj4.
> Were the original figures generated with GNUPlot?
> On the documentation, someone here started a similar effort,
> do not know the state though. You might wish to contact him
> for a discussion.
> Best regards,
> Paul.
> ----- Original Message -----
> From: "Gerald I. Evenden" <gerald.evenden at verizon.net>
> To: <osrs-proj at remotesensing.org>
> Sent: Saturday, March 08, 2003 4:30 AM
> Subject: [OSRS-PROJ] New projection routines??
> > To the best of my knowledge, I am caught up on OSRS's *projection*
> > needs.  If not, please queue up your requests.
> > In the mean time, I am working on few problems here: 1) review figure
> > generation using GNUplot, 2) finishing documentation on a couple of
> > minor projections and 3) considerations on general documentation.
> > PROJ.4 Discussion List
> > See http://www.remotesensing.org/proj for subscription, unsubscription
> > and other information.
