[OSRS-PROJ] proj-4.4.6 can't find epsg
Jack Bowling
jbinpg at shaw.ca
Wed Mar 19 18:59:31 PST 2003
On Wed, Mar 19, 2003 at 10:22:00AM -0800, Leah Roderman wrote:
> No, I haven't seen any output of "failed" or "succeeded" in my log. When I use "init=espg:2163" in my projection, Apache logs an error and MapServer outputs to browser the projection library error; using "proj=aea" I only see the error in the Apache log.
> I've done quite a bit of tinkering with the access, such as setting all permissions on for /usr/local/share/proj, changing Apache user to one with broad privileges, setting PROJ_LIB to a distinct directory owned by Apache user, testing /usr/local/bin/proj_def.dat as an option...etc. Nothing seems to make a difference. But to safely eliminate access to system libs as a problem, it seems unlikely that I could run proj from the command line if it couldn't access stdio.h. So, back to the access investigation...
Leah - Have you tried adding the proj library directory to
/etc/ld.so.conf and then running /sbin/ldconfig?
Jack Bowling
mailto: jbinpg at shaw.ca
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
