[OSRS-PROJ] NTv2 Datum transformation
Brent Fraser
bfraser at geoanalytic.com
Thu Nov 20 10:24:30 PST 2003
Frank,
I'm trying to work through a problem using proj4 to do datum conversions
using NTv2 (the Canadian NAD83/27 datum shift grid file). It seems that
Proj4 goes through the list of U.S and Canadian grids as specified in
pj_datums.c (line 75):
nadgrids=@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat
and uses the first one that returns a reasonable result. So when I do a
conversion on 49N 122W, it chooses the conus grid instead of the ntv2_0.gsb
grid.
I see that with cs2cs I can set the shift file by specifying
"+nadgrids=ntv2_0.gsb". Is there a way I can set the shift file to use using
a proj4 function call (I'm making a VB-callable DLL) ?
Thanks!
Brent Fraser
GeoAnalytic Inc.
Tel:(403) 213-2700
www.geoanalytic.com
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
