[OSRS-PROJ] Pb with conversion betwenn WGS84 and Lambert
Thu Nov 20 11:08:47 PST 2003
Aurélie Lebreton wrote:
> Hello
> I want to transform a pair of angular coordinates in datum WGS84 to NTF
> Lambert 2. I have written this line :
> ./cs2cs +proj=latlong +datum=WGS84 +ellps=GRS80 +to +proj=lcc +lat_0=46.8000
> +lat_1=46.8000 +lon_0=2.3372291 +k_0=0.99987742 +x_0=600000 +y_0=200000
> +a=6378249.2 +b=6356515 +ellps=clrk80
> The input coordinates are :
> 2d39'48882"E 48d32'8575"N
> But the coordinates transformed come out wrong and i don't understand why :
> 1575621.19      743408.43 0.00
> (the coordinates should turn around these values :
>  600000 2400000
> Does any one have the solution to this, or at least some in depth
> documentation on how to use proj ?
> Aurelie
Aurelie,
The main problem is your DMS specification: 2d39'48882"E.  I imagine
you mean 2d39'48.882"E (that is 48.882 seconds, not 48882 seconds).
You may also find you need to include +towgs84=0,0,0 in the NTF coordinate
system to ensure that the ellipsoid conversion is done, even though no datum
shift info is available.
With the DMS specs fixed I get:
warmerda at gdal2200[265]% cs2cs +proj=latlong +datum=WGS84 +ellps=GRS80 +to +proj=lcc +lat_0=46.8000 +lat_1=46.8000
+lon_0=2.3372291 +k_0=0.99987742 +x_0=600000 +y_0=200000 +a=6378249.2 +b=6356515 +ellps=clrk80 +towgs84=0,0,0
2d39'48.882"E 48d32'85.72"N
624110.53       395817.08 83.91
This value looks reasonable.  I am not sure why you were thinking the
northing should be in the range of 2400000m.  48d32' is less than 2 degrees
north of the reference point (46.8) and a degree is roughly 100000m.  So
the value I got (395817m N) is roughly 2 degrees north of the reference point
which makes sense.
Note that without good datum shift information the precision of the
conversion will not be great.
Good luck,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
