[OSRS-PROJ] Projection Information Weather Satellite
Clifford J Mugnier cjmce at lsu.edu
Fri Oct 3 09:53:02 PDT 2003
The projection is an Oblique Perspective or Oblique Horizon projection.  It
is definitely NOT Oblique Orthographic nor Oblique Stereographic.  It is
close (but not exactly) to an Oblique Globular.
Cliff Mugnier
LOUISIANA STATE UNIVERSITY
Hello all,
I'm new to the mailing list and was wondering if anyone knows the
projection (i.e. stereographic, orthographic, etc...) of the following
linked image.  I'm trying to write an app that will successfully navigate
this image (display lat / lon at cursor position), but I need the
projection info first.  I have successfully done this with a different
image (stereographic ) using Proj4.
Image link:
http://wwwghcc.msfc.nasa.gov/GOES/goeseastconusir.html
The image is derived from a geostationary weather satellite located at -75
degrees longitude and the equator.
Thanks in advance for any help you can provide.
Bryan
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
